I have searched the help docs and got zero results on this issue.
I am using latest tag wrangler (0.5.5).
When I try to rename certain tags, I am getting this error message: a.toLowerCase is not a function
For example #dreams and renaming to #dream
Another example is #George to #george
However, by testing the renaming function on other existing tags, it works fine.
I uninstalled the plugin, closed Obsidian, opened and reinstalled but that didn’t fix this issue.
Some of the tags I want to rename have between 50 and 100 occurrences.
I find great value in using tags so hope someone can help! Brad
Check Tag Wrangler’s GitHub issues to see if it’s been reported yet.
In the meantime, rename #George to something else and then rename the something else to #george.
bradsayers:
I have no idea why this happens, tho, since it doesn’t involve case.
Thanks, that didn’t work, got the same message.
Have checked github and there is a issue. I have posted my concern there…
gino_m
September 18, 2023, 8:32pm
4
Off topic: in Properties it is also difficult to delete back on a stem as well; you need to ESC out to finish editing a value. You noticed? (Try: dreams > dream, to stay with the example.)
gino_m
September 18, 2023, 8:34pm
5
“Rename twice” – I saw that somewhere before. Nifty.
The Tag Wrangler developer, PJ Eby, has issued an update to this plugin which fixed my immediate problem.
He also explained the underlying issue that I need to fix in order to not have problems going forward with the new properties editor.
You can see his full remarks at Renaming produces TypeError: t.toLowerCase is not a function · Issue #51 · pjeby/tag-wrangler · GitHub
system
Closed
September 26, 2023, 12:29pm
7
