A picture and text next to it (like in books)
Is there a way I could put a picture and have text to the side of it?
(Like you see in books)
And then in should continue
I tried to put a picture as a quote but I haven’t figured out how to make it smaller, so that I could’ve put something near it but I’m not really sure it will actually work
Maybe if there were some kind of columns
Do you have any ideas?
Like this?
Book pictures
no, mean the ability to place it somewhat like this
OK, if you don’t need additional things like frames and/or descriptions, use image positions.
Try.
You might be able to achieve this with just markdown depending on your theme. In the Blue Tapaz theme, I can write something like…
![[emoji.jpg#right|Caption Text]] Lorem ipsum dolor sit amet, consectetur adipiscing elit. Pellentesque suscipit nulla justo, non pharetra urna pretium vitae. Sed vel orci mi. Mauris egestas odio a suscipit finibus. Donec ipsum metus, volutpat ut lectus in, dignissim blandit quam.
2.3.15 Images:
Intro to Basic Image Position: You can add
  • |Left (can also use left, LEFT or L to replace the Left before),
  • |Right (right/RIGHT/R)
  • |Inline (inline/INLINE/inl/INL/Inl)
  • |Centre/Center (CENTRE/CENTER/centre/center/C) (the “centre” one is for the “Obsidian Default Image Position above only, because Topaz’s default image position is in the centre) into a image format to adjust the image position, e.g.
Intro to Image Caption: You can add
  • #Left|your captions (can also use left, LEFT or L to replace the Left),
  • #Right (or right/RIGHT/R)|your captions,
  • #center/centre (CENTRE/CENTER/Center/Centre/C) |your captions and
  • #inl (Inline/INLINE/inline/INL/Inl) |your captions into a image format to adjust the image position with a image caption, e.g.
Intro to Image Grid: You can add
  • |+grid into some images to grid these images in a line, e.g. Or type :exclamation:cssclass:img-grid​:exclamation: in YAML to make images arrange in a grid in the preview mode.
