Edit: rsdimitrov pointed out you can’t just use .view-content but have to specify markdown-source-view & markdown-preview-view.
Get THIS when in full screen?
Hate it? Want THIS instead?
Then add THIS to your obsidian.css file:
.markdown-source-view, .markdown-preview-view {
max-width: 700px;
margin: auto;
How’s your graph view looking after this modification?
Mine is a bit broken.
Edit: This fixed it:
max-width: 700px;
margin: auto;
Nice catch, thanks!
@Frederick_Lost, an excellent suggestion, and to think it just takes 4 lines of code !
I tried out, it worked fine, though without checking out the graph. Then I saw @rsdimitrov’s comment, checked out the graph and it was fine. Huh?
Compared his code with yours (the one I had copied): they’re identical. Huh?
Ah, I see, you corrected your original :+1:
So, thank you both for this !! :ok_hand:
Is it “my” theme or is the scrollbar attached to this width?
Where do you expect the scrollbar to be?
On the right most side :slight_smile: Screenshot with iA Writer for comparison:
Using
.CodeMirror-code {
	max-width: 700px;
currently is good enough for me.
Thanks for nudging me into the right direction, @rsdimitrov!
Thanks! I was wondering if others are getting the tags popup (suggestions after you type in #) to appear way off to the side? Not a big deal but wondering if that is normal or if I’m misimplementing something!
Sorry I am completely new in this world of changing the CSS . I also find same issue as you with the scrollbar, I would like it to be in the right. So, what should I add at the end of the CSS file, this?:
max-width: 700px;
margin: auto;
.CodeMirror-code {
max-width: 700px;
Just the latter. Be aware that this only limits the width, but does not center the text form; the text itself remains left-aligned using this method.
Perfect! Thank you very much, I will try it out
.markdown-source-view, .markdown-preview-view works for me but with the scrollbar.
CodeMirror-code does not work to centralise the content. Not sure why??
To all asking about the scroll bar: I’m unsure how to fix this for y’all. I personally hide the scrollbar because I find it unnecessary. Maybe trying finding a smaller
than the “…-view” divs to adjust.
.CodeMirror-lines, .markdown-preview-view{
   max-width: var(--view-max-width);
   margin: auto;
I found this can move the scrollbar to the edge of editor mode. But I cann’t do anything to the preview mode.
btw: how do you hide the scrollbar. I am newb…
Thanks, folks, for the inspiration to implement this.
This selector chooses only the contents of both source and preview, as far as I can tell:
.CodeMirror-scroll, .markdown-preview-section {
    max-width: 40rem;
    margin: auto;
That solved for me.
.CodeMirror-lines, div.markdown-preview-section {
  max-width: 800px;
  margin: auto;
FYI this will likely be less of a problem in 0.7!
While selecting the whole page there was a glitch, added ‘selected’ div as well.
.CodeMirror-lines, .CodeMirror-selected,  .markdown-preview-section {
  max-width: 700px;
  margin: auto;
Which font are using? It looks really cool!
