Zotero Data Explorer not working
I try to create a note from a Zotero item which includes a pdf with highlights. I use a special template to include the annotations.
The note is created, but at the same time there is an error message:
“ Error processing PDF: Command failed with exit code 1: /Users/Theo/Documents/DiscrProject/.obsidi an/plugins/obsidian-zotero-desktop- connector/pdfannots2json-darwin-x64 /Volumes/Other Backups/Professionals/Dzidzi guri 2024 Behavioral Public Administration BPA).pdf -w -n base_name -d 120 -f jpg -o ( /Users/Theo/Documents/DiscrProject/output _path -q 90 open /Volumes/OtherBackups/Professionals/Dzidzi guri 2024 Behavioral Public Administration (BPA).pdf: operation not permitted”
At the same time the Zotero Data explorer doesn’t work either. It says “No data retrieved” and gives the same error message as cited above.
I use Zotero 7.0.7 with an up to dat Better BibTex, Obsidian 1.6.7, and macOS 12.7.6
Making changes to the template, but that didn’t help.
Error zotero integration
