When I’m writing a note I usually have multiple other notes opened for that the initial note links to. These extra notes are often a lot shorter than the main one. I usually have the font size pretty large just because it reads nice for short notes, but the larger initial note is too long to pleasantly read.
Using ctrl + scroll still changes global zoom level, but using another shortcut (like ctrl + alt + scroll) changes relative zoom level of the note that us currently hovered over / active.
Store the relative zoom level so when a note is opened it retains it’s preferred zoom.
Have a button / shortcut to remove the relative zoom of a note so it can turn back to the global zoom level.
None.
Couldn’t find any.
You can control font size per note with CSS snippets. You should be able to set YAML metadata or a tag (like #longnote) and style notes based off of it (with use of a plugin, at least).
There is also a plugin that styles the active note differently. I don’t know if it lets you set custom styles.
