YAML Data should work within Canvases
I use YAML data to create dashboards for my notes, but since Canvases are written with JSON formatting, no plug-in recognizes them. Therefore, Canvases tend to be “invisible” to my workflows.
Either:
  1. Enable Obsidian to recognize a YAML block within a Card in the Canvas,
  2. Or create a YAML asset at the bottom (e.g. “Drag to add YAML block”) specifically for YAML to be entered & treated differently. There can be only 1 YAML block per Canvas to avoid any clashing.
I’m currently just adding YAML data directly to a Card in the Canvas, hoping that this feature will be added in the future and that I don’t need to go through all my Canvases in the future to add this information.
Similar to all of the posts related to how tagging should work properly within Canvas.
