- Create a note with this content:
[!QUOTE] Example 1
[!QUOTE] Line 2 of example 1
[!QUOTE] Example 2
Line 2 of example 2
Either in both examples or at least in one of them all lines would be rendered the same (grey background with a single “quote” symbol on the first line in the case of QUOTE with the default theme). This issue also occurs with the other callout versions (IMPORTANT, etc).
Styling is lost after the first line and only the first line of each example is rendered with grey background and the second line is rendered as a normal block quote. I can’t migrate to callouts in my vaults yet because I’m hitting this with many of my existing quotes and other callout use-cases for which I currently use block quotes.
- Operating system: Mac OS Monterey (12.2.1)
- Debug info:
Obsidian version: v0.14.5
Installer version: v0.13.30
Operating system: Darwin Kernel Version 21.3.0: Wed Jan 5 21:37:58 PST 2022; root:xnu-8019.80.24~20/RELEASE_X86_64 21.3.0
Catalyst license: insider
Insider build toggle: on
Legacy editor: off
Base theme: light
Snippets enabled: 2
Safe mode: off
Plugins installed: 6
Plugins enabled: 6
1: Hotkeys++
2: Advanced Tables
3: Style Settings
4: Calendar
5: Obsidian Git
6: Find unlinked files and unresolved links
