- Open multiple panes, activating them in turn before opening another
- Close the currently active pane
The most-recently active pane should activate
The first pane always activates
- Operating system: Windows
- Obsidian version: 0.10.1
The problem is due to a bug in the workspace.getMostRecentLeaf() method: it always returns the first/leftmost pane, because its iterator function returns true instead of false. This prematurely terminates iteration instead of actually searching through the panes to find the most recent one.
