We strongly recommend you to search the forum with possible keywords before submitting a new bug report. Please also try your repro steps with third-party plugins and custom CSS disabled and see if it’s still reproducible. If it’s an issue with third-party plugins or themes, try contacting the author for help. Once you’ve done the above, delete this line.
When using the theme ‘Blue Topaz’ the plugin ‘Dataview’ does not work correctly.
“dataview.list-view-ul” outputs only numbers with 1 digit. From the number “10” again a “0” appears, then a “1” and so on.
/* << Dataview list appearance >> */
.dataview.list-view-ul {
list-style-type: decimal;
The output should of course output the correct numbers greater than 9.
Only numbers up to “9” are output in the list. This is followed by a “0” and then again “1”, “2”, etc.
Obsidian 0.13.23
Dataview 0.4.26
