- create a new note
- create folder
images
- right click on images folder and set as default attachment folder
- in settings in
Files and links
set thenew link format
torelative path to file
- add any image to
images
folder - copy an image and paste it into the note from 1. step. Source:
## Obsidian image
![[images/51800_folder_icon.png]]
note: that this is not an actual valid markdown format. According to documentation (Basic Syntax | Markdown Guide) correct format is
therefore:
- add an additional image manually by following the correct format as such
. The final source is:
## Obsidian image
## Markdown image
Verify that both images are shown correctly. (note: images with spaces (if any) shall be encoded with %20
When pasting an image - it should(? maybe not?) follow the official/original markdown image format convention.
It should be possible to specify the title.
It should be possible to specify the ALT text.
Proprietary markdown format is used for images.
cannot set image title
cannot set image ALT text.
Obsidian version: v1.0.3
Installer version: v1.0.3
Operating system: Windows 10 Pro 10.0.19044
Legacy editor: off
Some users might be willing to put the project into a source repository where the original markdown format is used, such as github
It’s convenient to stick to original format, because then you get the maximum compatibility with the rest of the solutions (be it desktop apps or the web). As an another example, consider when user opens the above document in markdown file editor, then he sees this:
This is just to illustrate the core of the problem.
I understand that changing the images format might impact the existing users. So I propose that you could support the old solution, and the new solution. Please offer the option to migrate the existing format to the new format. Additionally you could add an additional option to dropdown new link format
, called relative path to file (official)
or something along these lines, if you don’t want to offer the migration.
I consider this to be a defect, as this image format is not an actual markdown image format, nor it offers the titles and alt texts… Please correct me if I am wrong.
