[[WIkilinks]] won't render/don't render correctly in Properties
Obsidian_Property_Links_Render_Bug
Insert a [[Wikilink]] in the property (text-type) and press enter: the link inserted either:
  • won’t render at all, leaving the space blank
  • keeping the previous link after modifying (as shown in the gif above)
    In both cases the hover preview summon the correct page
    Eventually after a few refreshing, closing and reopening tabs and relaunching the app made the link visible/correct again
Yes
Obsidian version: v1.7.5
Installer version: v1.6.7
Operating system: Windows 11 Home 10.0.22631
Catalyst license: insider
Insider build toggle: on
Plugins installed: 69
Plugins enabled: 47
1: Dataview v0.5.67
2: Quick Switcher++ v4.6.2
3: Text Transporter v1.0.12
4: Auto Link Title v1.5.4
5: Hotkeys++ v0.2.7
6: Commander v0.5.2
7: Paste URL into selection v1.7.0
8: Paste image rename v1.6.1
9: Lazy Plugin Loader v1.0.18
10: Note Refactor v1.8.2
11: Excalidraw v2.6.7
12: List Callouts v1.2.9
13: Surfing v0.9.14
14: Hover Editor v0.11.21
15: Better footnote v1.0.1
16: Calendar v1.5.10
17: Callout Integrator v1.1.4
18: Callout Manager v1.1.0
19: Footnote Shortcut v0.1.3
20: Fullscreen mode plugin v0.1.2
21: Grandfather v1.0.1
22: Iconize v2.14.4
23: Map View v5.0.3
24: Natural Language Dates v0.6.2
25: PDF++ v0.40.13
26: QuickShare v1.3.1
27: Review v1.6.5
28: Smarter Markdown Hotkeys v1.16.4
29: Sortable v0.3.1
30: Soundscapes v1.4.0
31: Supercharged Links v0.12.1
32: Tag Wrangler v0.6.1
33: Templater v2.9.1
34: Text Extractor v0.5.2
35: Text Format v3.1.0
36: Admonition v10.3.2
37: Annotator v0.2.11
38: Auto Card Link v1.2.3
39: Emoji Toolbar v0.4.1
40: ExcaliBrain v0.2.15
41: Gallery v0.5.8
42: Itinerary v1.3.0
43: Settings Search v1.3.10
44: Style Settings v1.0.9
45: Tidy Footnotes v0.1.2
46: Typewriter Scroll v0.2.2
47: Zoom v1.1.2
Does it happen in the Sandbox vault or with the Restricted Mode turned On ?
Both in Sandbox and in Restricted mode the bug doesn’t occur
Then it could be due to one of the plugins you use (or some “interferences” between some of the plugins) :grimacing:
Make sure the your plugins are all up-to-date :innocent: … and if they are, the next step would be to spot the potential culprit(s) :no_mouth:
The plugin Divide & Conquer could help you with that :blush:
Thanks a lot for the plugin suggestion! I’ll try out disabling my plugins and I’ll share what I find out
