Hi,
When I switch between Edit and preview mode in a pane the text in de edit mode start not at the top of the pane window. The same occurs when both pane’s are next to each other.
Is this a normal behavior or do I have to set some setting to have both pane’s aligned?
Thanks.
Click for an image example:
https://imgur.com/a/enGG1BZ
To start, you need to check the behavior in default theme and without any plugin.
