I honestly cannot find the settings to this, and don’t know if it’s a plugin or where it comes from.
I’m using… any ideas?
If you do Show debug info from the command palette, and post that information here, someone might be a little better equipped to help you. You might even understand it yourself, when seeing which plugins you’ve enabled.
I thought I’d seen this solved by OP before…?
Make.md plugin
It’s a plugin. It may be obvious which one when you look at your list of installed plugins.
