When quick switcher finds nothing, add a hotkey to search the same thing vault-wide
If I use quick switcher and it finds nothing, it is very likely that I will want to vault wide search the same thing to see what I already know about it.
While in quick switcher, pressing “ctrl+shift+F” will immediately search the same thing in “Search” core plugin.
(Other hotkey will also do, not using “ctrl+F” is to avoid confusion with in-file search.)
Manually copy paste the words to “Search” plugin.
This post is different, only a UI issue.
