Subject: Persistent Issue with Obsidian on Poco X4 Pro
Hi Obsidian Team,
I’m experiencing a persistent issue with the Obsidian app on my Poco X4 Pro, running Hyper OS version 1.0.9.0.TKCINXM. When I try to create a new vault or access an existing one, the app returns to the main menu after I select the file or vault and click “proceed,” without completing the action.
Here are the details of the issue:
- Problem Description:
When I try to create a new vault or access an existing one, Obsidian sends me back to the main menu after I select the file or vault and click “proceed.”
There’s no error message or any clue as to what’s preventing the action from going through.
- Troubleshooting Attempts:
I’ve checked and configured all necessary storage permissions.
I tried using the device’s default file manager, created a vault with another file manager, and tried accessing it directly in Obsidian, but the problem persists.
I’ve disabled the MIUI file manager and reinstalled the app.
I’ve also tested other versions of Obsidian, but the issue remains unresolved.
- Device Information:
Model: Poco X4 Pro
Hyper OS Version: 1.0.9.0.TKCINXM
Obsidian Version: 1.7.7
I’d appreciate it if you could provide any solution or update to resolve this issue. Please let me know if you need more details or if there are any specific tests I can perform.
Thanks for your attention, and I look forward to your response.
