When I create a todo checkbox with CTRL+Enter then press enter, a new todo checkbox is created. But when I tab into it, checkbox stays and I need to delete it everytime. Is it possible to delete checkbox when I press tab on second line?
I don’t understand what you mean by “tab into it”.
If you hit enter on a blank checkbox (or a bullet list), it will delete it. So hitting enter twice is a quick way to end a list.
enter
“If you hit enter on a blank checkbox (or a bullet list), it will delete it.” works. Thank you.
