When a base is in the sidebar and no note opened in the main pane new note from base does not include filtered properties
  1. Create new base file.
  2. Add filter ‘tags.contains(“test”)’.
  3. Pin base file to the sidebar.
  4. Close any other notes in the main pane.
  5. Try to create new note from base.
Created note should have tag “test”.
Created note doesn’t have any tags of the tags property.
Obsidian version: v1.9.6
Installer version: v1.8.4
Operating system: #24~24.04.3-Ubuntu SMP PREEMPT_DYNAMIC Mon Jul 7 16:39:17 UTC 2 6.14.0-24-generic
Language: ru
Catalyst license: insider
Insider build toggle: on
When base is not in sidebar or if any other note is opened in the main pane, the new note is created with tag, as expected. The same happens with any other filtered properties. Properties, added to columns, are added to the new note normally, the problem is only with filters.
thanks!
will be fixed 1.9.7
