What Do You Do With Research Notes Once a Project Is Finished?
I’ve been thinking about how to organize research notes so they remain useful long after the original reason for collecting them is gone.
One thing I’ve noticed is how easily information from different subjects can overlap. You might save something while learning about one topic, only to realize later that it could be useful for something completely different.
Sometimes I come across related ideas while reading completely different sources. For instance, I might save something from Finance Nest Blog and later find a similar point discussed somewhere else. That makes me wonder whether it’s better to keep notes organized by their original sources or connect them based on the ideas they share.
I’m considering a simpler approach in Obsidian, where notes about individual sources are kept separate from broader topic notes, with links connecting related ideas.
What I’m unsure about is how much organization is actually helpful. I wouldn’t want to spend more time maintaining the system than using the information. There’s also the issue of keeping older notes accurate when information changes over time.
For those who use Obsidian for research, learning, or managing personal knowledge, how do you handle this?
Do you organize everything around individual projects, or maintain a central collection of topic-based notes that you can return to whenever needed?
And once you’ve finished researching something, do you review and reorganize the useful notes, or simply leave them where they are until you need them again?
I’d be interested to hear what has worked for you, especially if your approach has changed over time.
Hi sis :D, what about write the notes link to the daily notes.
I just answer to an another topic to talk about advantages of use daily notes as main page!
  • I think if it’s ok, some small knowledge not need to create a new note, just write in the daily notes.
  • If it’s big, create just one folder to save the notes, but don’t create more folders.
  • Set notes a properties such as Library of Congress Classification, so I think this can use bases plugin to filter.
    • If I not use Library Classification, I would take long time to consider the theme.
    • I don’t use the tags to save Library Classification, just use the type list.
  • If you want to do a big project ,and want to find them faster, you could save the links to a new note, or use bases filter.
  • And after it ends you could move the project note that fall of links to the folder that saves the notes useless.
All my notes have a YML attribute called ‘status’ which contains values like draft, review, active, complete, and archived.
Status Description
draft New, partially written, or incomplete
review Ready for editing, verification, or refinement
active Currently useful and actively maintained
complete Sufficiently finished and usable
archived Retained but no longer active
When I’m done with research or work involving a note, I mark the status as archived and leave it where it is. In case I need it in the future, it’s easily searchable. Also easily filtered out in search based on status when I don’t want to see archived notes in my results.
Disclaimer: I use folders heavily (Johnny Decimal) so leaving the content where it was created makes more sense to me.
:person_raising_hand: All of the above. Also for personal and work operations and record keeping.
That works incredibly well in my experience, with very tolerable overhead.
I do close to zero retroactive maintenance. Once in a while, I’ll move a note or folder to make exporting/sharing/publishing easier. It’s brief and only for utility, never for conceptual re-categorization.
:placard: No digital reorganization just because of real-word categorical updates. Not in this system :guard:.
This is one of my favorite technical features of Obsidian. Content blocks can be embedded in any note. This leaves me no excuse for duplicating information, with the exception of intentionally keeping certain version histories. With embeds, I actually find it fun to maintain a “single source of truth” architecture as the info changes over time. Update it at its source, and it instantly updates all over the place.
When a project is over, I archive the notes that had to do with process. I do not archive notes related to research. “Research”, “knowledge”, “information”, “reference”, however you like to think of those, stay in my vault for the reason you mentioned: they continue to be useful and reusable.
So, linked properties are my organizational hub. Still, for quick filling (that is, just places to put stuff without having to second-guess or rearrange over time), my top-level folders structurally support the exact separation you mentioned:
- archive
- knowledge
- operations
The top isn’t always crisp and clean like that. I’ll sometimes move active projects or portions of operations/admin to the root. But over decades of digital organizing, since before Obsidian, my folders consistently whittle down to those three.
Inside:
- archive
- knowledge
	- entities
		- organizations
		- people
		- sources
	- topics
		- topic 1
		- topic 2
		- topic 3
	- me
- operations
	- admin
	- contacts
	- dailies
	- events
	- finance
	- health
	- hobbies
	- kits
	- legal
	- opo
	- projects
	- reminders
	- uncat
knowledge contains really only two types of notes, which makes filing quick and intuitive for me.
  • entities: people, organizations, sources
  • topics: topics contain research notes, literature notes, etc.; they naturally link to entities and can of course link to one another
These are the notes that stick around beyond the span of their initial operations.
Here be folders exposition unrelated to your questions.
  • me contains me-related knowledge and records such as family trees
  • kits holds lists, how-tos, procedures, reference sheets, and the like
  • opo is “other people’s ops”
    • family members’ health and finances that I manage
    • things for friends and clients that don’t fall under work
    • info and logs for accounts people have given me access to, ranging from database access I’ve requested to helping a friend set up their newsletter
  • uncat is for uncategorized files. I love this folder. It hates me. I rarely put stuff in it except when I’m very tired or very in a rush. Mass imports arrive here too.
    • I immediately prepend the arrival date to the folder or file’s name.
    • Six moths later, if it’s still uncat, to the archive it goes. No appeals.
    • If I miss it one day, I can always fish it out.
In practice, I name the “knowledge” folder “kb” for the concept of a knowledge base, and the “operations” folder “life ops” for its implications. Another reason is to keep the paths distinct from other uses of those generic words. Also, I like them short.
