If I only press tab, also have the level function, can I know what is the bullet point use for? or some function can be used if using bullet point for sorting or? Thank you so much
Bullet points mark text as an unordered list (a list where the order isn’t important).
Indenting text without a list marker marks the text as code. That doesn’t seem to be happening in your screenshot, so I guess in that situation it’s a convenience for editing.
I think if you switch to Reading View, the list indentation will remain and the non-list indentation will disappear.
