Known Issue
Edit Mode
Read Mode
- As you can see in the Edit Mode, I just write a list in a quote. The first line renders as you would expect but the second line is off rendered. However, in the read mode, everything is rendered as normal.
- I tried to write in multiple ways but it still ends up like that.
- I also tried to go back default theme but got the same result.
