Webview Fails to "save to vault"
I open up the webveiwer, navigate to a website, and click option to save to vault. Nothing happenes
Y
I should have a new note in the root of the vault with the contents of the website.
Nothing happens
Obsidian version: v1.10.6
Installer version: v1.10.3
Community theme: Simply Colorful v0.4.3
Plugins installed: 12
Plugins enabled: 11
1: Iconize v2.14.7
2: Tag Wrangler v0.6.4
3: Templater v2.13.1
4: Dataview v0.5.68
5: Syncthing Integration v2.3.0
6: Advanced Tables v0.22.1
7: Advanced URI v1.45.0
8: Editing Toolbar v3.1.18
9: Columns v1.6.1
10: Buttons v0.9.2
11: Importer v1.6.21
works for me.
Please, post a screen recording of it not working in the sandbox vault
I had the same issue and tracked it down to the save folder not exsisting:
Steps to reproduce:
  1. Enable plugin and enable restricted mode
  2. Set “Saved page folder” to empty
  3. Save a website → it works
  4. SEt “Saved page folder” to a folder that does not exsist
  5. Save a website → nothing happens
  6. Create said folder, Save a website → it works again
Expected behavior from me would be that the folder is created if it does not exist.
