- My plugin Agent Brain (id
agent-brain) is listed in the community directory with the repositorymucahitkumlay/agent-brain. - The repository is public.
manifest.jsonis at the root of the default branchmain(version0.18.0), and release0.18.0hasmain.js,manifest.jsonandstyles.cssattached. - Go to community.obsidian.md → Plugins → Agent Brain → … → Check for new releases.
Did you read and follow the Troubleshooting Guide? Yes
The directory reads manifest.json from the default branch of mucahitkumlay/agent-brain, finds version 0.18.0 and its release, and updates the entry.
The page community.obsidian.md/account/plugins/agent-brain/check-release shows:
“We couldn’t read manifest.json from your repository’s default branch.”
The entry overview also shows outdated repository data:
- Current release: 0.17.1, while the latest release on GitHub is 0.18.0
- Stars: 3, while the repository on GitHub currently shows 0
Obsidian version: 1.14.4
Installer version: 1.14.4
Operating system: Windows 11 Pro 10.0.26300
Catalyst license: none
Snippets enabled: 1
Plugins installed: 1
Plugins enabled: 1
1: Agent Brain v0.17.1
The manifest can be read from all of these:
https://raw.githubusercontent.com/mucahitkumlay/agent-brain/main/manifest.jsonhttps://api.github.com/repos/mucahitkumlay/agent-brain/contents/manifest.json
manifest.json is unchanged apart from its version: id, name, author, minAppVersion and isDesktopOnly are the same as in the versions the directory accepted before.
Could you check why the directory can’t read it, or refresh the entry’s link to the repository?
Screenshots of the dashboard and the error page are attached.
