  • Enable VoiceOver.
  • Attempt to Navigate the app by keyboard.
  • Attempt to open another vault.
  • See the option to expand the right panes.
  • Be able to close the dialog box without opening a new vault.
  • Be able to tell the difference between the left and right Expand/Collapse buttons. Right now they only say Expand or Collapse which is not enough when navigating by keyboard.
  • The button to expand the right panes is invisible. You need to hunt for the Expand button on the right side with the mouse right now.
  • The dialog to open another vault can’t be closed until you find the close button with the mouse pointer. You should be able to close the window with Escape or Cmd-W or navigate to the close button with normal VoiceOver keyboard navigation. You need to hunt for the close button with the mouse right now.
  • Operating system: macOS Big Sur 11.2.3
  • Obsidian version: 0.11.13
There is already FR to improve keyboard navigation of some modal windows.
I am gonna move this to FR as well for VoiceOver.
I hope we can get better at accessibility in the future.
That sounds good. It’s not too bad at the moment and really appreciate how accessible it already is.
I’m using Voice Control on my Mac today because my RSI is acting up.
However, it looks like I can’t use Voice Control with Obsidian. I’ve defaulted to talking to Drafts to input text and then cutting and pasting into Obsidian.
Luckily, I don’t need Voice Control every day, but other users might. Please add this to the Roadmap if possible.
Let me know if I’ve missed a setting to turn this on in Obsidian.
Thank you.
Commenting just to strongly communicate an upvote.
Related: Services item in editor menu on Mac.
Merged another thread.
Accessibility is critical and should be further implemented.
Another issue with VoiceOver enabled is the inability to type anything into the search box. The error says ā€œtable not foundā€ until you turn off VoiceOver so you can type in a search term.
Navigating settings using VoiceOver many controls cannot be accessed/enabled/disabled
Start Voiceover (Cmd-F5)
Start Obsidian
Using VoiceOver keyboard commands navigate to and Open Settings
Using VoiceOver keyboard commands navigate to and select Core Plugins
Using VoiceOver keyboard commands navigate to and select the Sync plugin
From this point there seems to be no way to toggle the setting on or off
That the plugin can be activated or deactivated as desired
No control of the setting can be accessed via VoiceOver actions
  • Operating system: Mac OS Big Sur 11.4
  • Obsidian version: 0.12.5
This is consistent across all settings; the actual controls are not accessible from VoiceOver.
I’m late to this party but I strongly up vote this feature request.
For background, I was excited to discover obsidian and try it on my Mac, but unfortunately it doesn’t support the speech recognition built into MacOS.
Actually, it’s more puzzling than that. MacOS allows you to do ad hoc dictation by pressing the command key twice. That works fine with obsidian.
But you can also turn on Voice Control to control your Mac with your voice, which saves a great deal of wear and tear on your carpal tunnel. But it disables the ad hoc dictation described above and replaces it with a more robust version of speech recognition. That’s a good thing for most apps other than obsidian, but for some reason obsidian doesn’t support that speech recognition. Which means I have to turn off voice control in order to dictate into obsidian. Sadly, that’s a nonstarter for me and my aging hands.
Would that I had the technical chops to provide a solution for this but I don’t. That said, I’d love to see a fix in some future version of obsidian.
