[visual] Property tags not aligned with the other properties
  1. Create a new note.
  2. Add some properties.
  3. Add tags.
Tags aligned with the other properties.
Tags is not aligned with the other properties.
Obsidian version: v1.4.1
Installer version: v1.3.5
Operating system: Windows 10 Home 10.0.19045
Catalyst license: supporter
Insider build toggle: on
Legacy editor: off
As you can see from the screenshot, the alignment of all properties is correct, but tags is suddenly left a few pixels. It’s a very minor thing, but it is annoying once you have spotted it. :wink:
Properties added after follow the correct alignment again.
A quick playing around with the developer tools seem to indicate that the div.multi-select-container is offset:
The top one (green) has this computed:
Corresponding to app.css:8366 and app.css:5201.
.metadata-property:not([data-property-key="tags"]) .multi-select-container {
  padding: var(--size-4-1) var(--size-4-2);
The bottom one (salmon) has this computed:
Corresponding only to app.css:5201.
will be fixed 1.4.2
