Disclaimer
Is this plugin vibe-coded beyond the author’s ability to comprehend how it works? Yes
Community Directory: Visual Math Editor
Hi everyone! I’m the developer of Visual Math Editor, a free, open-source plugin for editing equations directly inside Obsidian notes. The goal is to make fractions, roots and other structures easier to write without needing to learn LaTeX first.
- Visual: build formatted fractions, roots, subscripts, superscripts, integrals and sums using buttons and placeholders.
- LaTeX: edit the equation source directly.
- Hybrid: edit the source on the left or the formatted equation on the right, with synchronization in both directions.
The editor opens below the relevant note paragraph. Equations are saved as ordinary LaTeX/Markdown, and you can reopen them to make changes. It uses MathLive and runs locally, with bundled fonts and no telemetry.
There are also optional chemistry notation and balance suggestions, unit conversions, a periodic table, function graphs and a complex plane.
I’d appreciate volunteers for a 5–10 minute usability test:
- In a new test note, open ∑ → Visual → Math and create
5/8, leaving the editor open. - Switch to Hybrid and change the source to
\frac{3}{4}. On the visual side, append a plus sign and a square root ofx; check that the source changes too. - Click Insert equation, then place the cursor inside it and use ∑ to reopen it. Check that the fraction and root are preserved.
Was anything confusing? Did you notice awkward symbol spacing, synchronization problems or too many steps? Feedback here or through the repository’s Issues is welcome.
Download, source and installation instructions — the README links to the compiled installation ZIP and community-directory page. If the plugin is not yet searchable in your app’s catalog, use the manual installation instructions.
Thanks for trying it!
