Visual artefacts when hoovering cursor over links
There are visual artefacts when hoovering cursor over links: thin long dark line below the link.
Hope you see it on a screenshot. If not, I can record a video. The issue is reproduced on light theme as well, but the line is white.
  • Operating system: Catalina 10.15.4
  • Obsidian version: 0.6.0
  • Using custom CSS: no
That’s the hover preview. Your link is just not working or the destination file is empty.
If your link goes to a valid file with text inside, that would show up.
I will be putting a fix for the next version so it shows an empty box (perhaps with a tip) instead of a thin line.
Thanks!
Note, please, that these artefacts are available when you Ctrl-hover the links even when Page preview is disabled in the Settings.
Ah I can see that issue as well. Will fix along with the first one.
Fixed in 0.6.1, moving to graveyard :zombie:.
