Visibility of right side bar
The menu ribbon of the right sidebar disappears with the extension of the edit field of the note.
Would be fine to have a stable menu ribbon for right side bar regardless of the size of the edit field of the note.
Using the handle between edit field and sidebar.
None.
What do you mean by the “menu ribbon” — the tabs at the top that you use to switch sidebar views?
