holding down one of the hjkl keys
@santi if you’re replying to kohane27 typing “jk”, I presume they are mapping the key sequence “jk” to <ESC> in insert mode in Vim, which is a common ergonomic trick. It’s not about navigating or repeatedly pressing j or k.
santi
October 24, 2020, 11:54pm
42
Hey @rigmarole yeah forgot to tag @kohane27 on my reply
Got you, thanks for the clarification. I thought jk was referring to pressing and holding j or k
I wasn’t familiar with that way of using escape. I’ve tried fd and currently I useCAPSLK
but what I can recommend is this volcano plug in (linked below) for setting up an .obsidian.vimrc to configure it
I currently have this settings
nmap j gj
nmap k gk
and it works great so far.
I spent some time playing around with the temporary Volcano plugin loader for Obsidian, and figured it’s actually very easy to make this Vimrc feature happen!
So no guarantees whatsoever, but the following seems to work (I called it vimrc.js under ~/volcano/plugins):
class VimrcLoader {
constructor() {
this.id = 'vimrc-loader';
this.name = 'Vimrc loader plugin';
this.description = 'Auto-loader for Obsidian Vim commands on startup.';
this.defaultOn = true; // Whether or not to enable t…
@santi
Apologies for my lack of clarity! Yes I meant remapping jk for Escape in Vim.
@rigmarole thanks for clearing that up!
santi
October 25, 2020, 12:11am
44
no worries, @kohane27 give that plug in a try, I think it might be what you need
My vim feature request: using ‘o’ should insert the - [ ] or whatever block you’re in. Not necessary, but would rule.
This one is crucial for me. Added matchbrackets.js manually and it seems to work fine. Asked developers to added in next versions. If not, will provide a plugin which adds this file.
santi
November 2, 2020, 12:11pm
47
that’s be awesome @mrjackphil in the mid-time do you have the matchbrackets.js to put on the console?
I use Ctrl+C or Ctrl+[ for esc on vim-mode. F.Y.I.
It would be hoped to use vim-mode feature for search, command palette, open note, …
santi
November 2, 2020, 8:15pm
50
thank you @mrjackphil it works great, hope it’s implemented with the next update of obsidian, if not a plug in would be amazing thanks!!
I use :imap jj
This has be be applied with every session though.
I use this plugin https://github.com/esm7/obsidian-vimrc-support to load imap jj <Esc>. It works great for me.
I was missing matchbrackets functionality so much so did a plugin
willcan
December 4, 2020, 2:37pm
55
For some reason my imap jk <esc> worked for a minute and now just deletes the jk and remains in insert mode. Any ides?
jtmusky
December 16, 2020, 7:38pm
56
imap jj <Esc> is working for me. Using Obsidian 0.10.0
jtmusky
December 16, 2020, 8:16pm
57
thank you for providing this plugin
imap jk <ESC> deletes jk without exiting insert mode for me on OSX with Obisidan 0.10.6 and the obsidian-vimrc-support plugin
EDIT Changing this to imap jk <Esc> did the trick
If I can use Vim navigation keys like j, k, ctrl+u, ctrl+d and search using /word in preview mode would be great.
Here’s my latest struggle: I can navigate to the link under the cursor with Alt+Enter, but when I try to remap this using the following command, it doesn’t work.
nmap gd <A-CR>
Anyone have any luck remapping this?
PhucLe
February 4, 2021, 1:35am
61
Does holding down one of the hjkl keys not work for you?
Hi, holdiing down j/k/l/h for moving the cursor indeed does not work for me. I have to resort to f command to move around in the same line.
Do you know any fix for this while we all waiting for the neovim backend?
