Using vim-mode for editing, in a file containing a lot of completed tasks (in this case, instances of recurring tasks), execute :g/^-\s\[x\]/d
Matching lines are deleted
:43d not an editor command (or some other line number).
Operating system: Windows 10
Debug info:
Obsidian version: v1.0.3
Installer version: v0.15.9
Operating system: Windows 10 Enterprise 10.0.19044
Legacy editor: off
Community theme: Obsidian gruvbox
Snippets enabled: 5
Plugins installed: 8
Plugins enabled: 8
1: Calendar v1.5.10
2: Tasks v1.17.0
3: Advanced Tables v0.17.3
4: Vimrc Support v0.7.3
5: Admonition v9.0.5
6: Full Calendar v0.6.1
7: Dataview v0.5.47
8: Commander v0.3.0
I opened the sandbox vault, enabled vim mode, create a file with multiple lines of
- [x] Task
And then ran the same two commands. The first (global, but no delete) did return all the lines. The second (global with delete) still returned a variant of the same error (different line number)
I changed the sandbox vault to source mode, all results the same
I copied the text of my file into this demo, the results are the same.
Given all that, it seems like an issue in codemirror (which, if I understand correctly, is what Obsidian includes to get vim-mode?) rather than Obsidian itself.
If that’s correct, do you have any advice on how I raise a bug with them?
Now we can mark this solved. I engaged with the upstream community, they resolved it, and I’ve confirmed that it has been successfully integrated into Obsidian
