We strongly recommend you to search the forum with possible keywords before submitting a new bug report. Please also try your repro steps with third-party plugins and custom CSS disabled and see if it’s still reproducible. If it’s an issue with third-party plugins or themes, try contacting the author for help. Once you’ve done the above, delete this line.
I am trying to get the hang of obsidian vim, but looks like there is a serious problem with it. Whenever key mapping that It causes to exit the normal mode it stops at that step, it work fine of course in gVim. lets say a very simple command like :nmap ii
stops after going into the insert mode and don’t put the i after that (same with O o c keys I have tried, but a key sequence like re
which stays in ). that is really weird, I wonder how people using at all
for example, map :nmap w ii
to switch to insert mode and type i.
switch to insert mode, type i
it switches to insert mode but not doing anything after that
- Operating system: Windows10, version 0.14.06 (installer 0.14.05)
- Debug info:
