Enable vim and templater plugin.
Set up this template:
<% tp.file.cursor(1) %>
Randomtext-<% tp.file.cursor(1) %>
Insert this template while in vim normal mode and in insert mode. When in normal mode the second tp.filecursor(1) is placed at the beginning of the second line, instead of after the ‘-’ at the end of the third line.
In insert mode the cursor is placed correctly.
In normal mode the second tp.file.cursor(1) should place the (second multi-) cursor where the second instance of tp.file.cursor(1) says it should go.
The second tp.file.cursor(1) should place the (second multi-) cursor at the end of the third line.
- Operating system:
Linux OpenSuse 15.4
- Debug info:
Obsidian version: v1.1.9
Installer version: v0.15.9
Operating system: #1 SMP PREEMPT_DYNAMIC Fri Dec 9 09:29:22 UTC 2022 (e9c5676) 5.14.21-150400.24.38-default
Legacy editor: off
Plugins installed: 1
Plugins enabled: 1
1: Templater v1.16.0
