- Enable Vim Mode
- Create a New Note
- Put the following example markdown snippet into the note:
- $$f(0)=0$$ bar
- Enter normal mode, and scroll around past the math block with the L key.
The cursor should be at the correct position horizontally
The cursor has some sort of offset applied to it.
Obsidian version: v1.6.7
Installer version: v1.6.7
Operating system: #1-NixOS SMP PREEMPT_DYNAMIC Mon Aug 19 04:04:32 UTC 2024 6.6.47
- Per the instructions on Linux bugs, I tested it on KDE Plasma with the AppImage. I have no way at the moment to test this on Windows or Mac.
