- Open the sandbox vault.
- Enable vim mode.
- Create a new canvas.
- Create a new card.
- Paste the following text into the card
foo
- Make sure to be in normal mode and place the block cursor in the code block. It will be invisible (seems to be behind it). If you enter insert mode the normal cursor renders fine.
The block cursor is visible.
The block cursor is not visible.
- Operating system: macOS
- Debug info:
Obsidian version: v1.1.8
Installer version: v1.1.8
Operating system: Darwin Kernel Version 22.2.0: Fri Nov 11 02:04:44 PST 2022; root:xnu-8792.61.2~4/RELEASE_ARM64_T8103 22.2.0
Catalyst license: vip
Legacy editor: off
