@Licat would be the one to comment on that, although I wouldn’t expect it to take that long. A quit and restart is always healthy! (The first load after a big vault change might take a little longer than usual.)
Should be pretty easy to tell just by looking at CPU usage of the app without doing anything. It should be close to 0 when the app is done indexing.
Apologies for all the moving around! I merged the wrong threads, I’ve moved the topic back to its original thread (hopefully correctly). Lesson learned: Do not attempt to reorganize threads without enough tea in ya!
I’m also hoping for the feature Mike describes. I was thinking for any file in preview, the app should know which blocks have references, because these are the only blocks that have caret IDs attached. It could then search for these IDs in the background and display a number in the preview to the side (like Roam or in some other way). Bonus points if the number is clickable and opens a search pane or something to show all the links to that referenced ID.
+1 for this. The beauty of obsidian is that it stores everything in simple files, if it can be implemented it will be cool.
I am from Roam as well & have noticed limitations as well within Obsidian in regards to the block refs
One of the key things I would love is if I could see the content of the block ref vs *title & block UID number. In Roam when the cursor is within the block then you can see the ID number
It is a little different here as when the term block is used this could encompass a paragraph etc where in Roam it would be 1 bullet pt, 1 idea. So a paragraph here would be a bit different w/o using the embed but I would like the ability to take 1 idea (bullet pt) & see it inline with the other content. If I cannot see the content & only the UID number it is not very useful for me. Although I can use the cursor hover these are extra steps that take away from fluidity. I can embed it but since the link is now not in context it also creates friction points for me.
As mentioned I would also like to see the number of items being referenced from the original. I am not sure how it will work with the WYSIWYG editor but right now I have no idea if a block has been referenced if in the preview mode.
I want to ref my blocks in content but cannot do so in Obsidian as I have to keep stopping to figure out what it is or use an Alias. That’s not a very useful step if you use block ref a lot, though
Hi! I justed submitted a plugin to the community plugins that I think folks on this thread will be interested in. It adds the count of a block reference next to the reference, along with a way to see where those references are made!
You can see a preview of it here: Block Reference Counters Preview - YouTube
This is great, I suggest you open a new thread in “share and showcase” for follow-up discussions.
that’s really good, but i can’t install it, would you be so kind and tell me how to do so
I haven’t used Roam intensively, but I’m all for this feature request. I think it’s a key feature for any bi-directional notetaking app.
A similar feature in VS Code is find all references/ peek reference. An example is shown below. That is, wherever a reference appears, you can list all references.
Thank you, this was one of the key features I was missing in Obsidian!
Though splitting into atomic notes is a possibility, and it can be automated, the problem is that separate notes cannot be linked as an indented structure like in an outliner. For those familiar with blocks and indenting capabilities, Obsidian becomes a huge tradeoff. Going by the exchanges on the discord and the forum, heavy Obsidian users do not use blocks at all and therefore I doubt if this will find broader support going forward.
nice job!
The video is not available. I don’t see how to access the “button” that the release notes say is added to Obsidian.
If I look at outliners - Logseq, Roam, Workflowy/Dynalist, for example - I perceive the later as being most effective as outliners with the others having extra features but some trade off.
But, Obsidian is not an outliner at all.
However, it would be possible for a plugin to create a fully indented outline structure from blocks, headings or files quite easily. It would need three components:
  1. Gathering everything into a single markdown file using headings, (possibly outlines under headings if more than five levels are required);
  2. A markdown/OPML exporter/importer;
  3. An editor/viewer that presented the OPML as an indented outline, with all the outliner features that are wanted. Could even be pure CSS if limited functionality is needed.
An alternative to the last stage is opening the OPML in another outliner such as Workflowy/Dynalist.
What this wouldn’t do is make everything in a Vault part of an outline. If that’s needed, it’s probably best to open the folder in Logseq.
This is true, and many do it, and it’s a type of faux block, but I don’t see any advantage to it myself. The idea derives I presume from the zettelkasten community and Ahrens etc. But even a short phrase can contain many ideas (see analyses of any ancient text) and a single idea may take a lot of defining.
That’s certainly true for me.
What I want from any note will vary and blocks are too restrictive. I may need just a word, or a phrase, a fact or even an explanation covering several paragraphs. And I also want the context, if there is one. I find the easiest solution is much longer notes or documents with highlights defining what I want with the ability to use those highlights.
How do you link parts form a long note without a block reference?
Go to header, look at the highlights in context. Highlights already extracted.
Would you be able to explain a bit more? I am keen to learn further. TIA
I’m not sure what you want explaining.
There are many ways of working using highlights, and a number of plugins designed to suit different approaches. The Extract Highlights plugin does most of this (links to note rather than header, so header has to be added yourself).
But it’s a different way of working.
Students in ancient days had books and some had highlighters. One tribe of that ilk drew a line down the margin, while the larger tribe highlighted specific words, phrases and paragraphs. I think this is the same difference in approach.
