Vertical Lines Inside KaTeX/LaTeX Inside Table Cells Are Rendered as Doubled Vertical Lines
  • Write $|\mathbb R|= \mathfrak c$ once inside a paragraph and once inside a table cell.
Both $|$ should render as a single vertical line (|).
Inside tables the $|$ are rendered as $|$ (doubled vertical lines)
	Obsidian version: v1.9.10
	Installer version: v1.9.10
	Operating system: Windows 11 Pro 10.0.22631
	Catalyst license: insider
	Insider build toggle: on
	Plugins installed: 0
	Plugins enabled: 0
Also, there’s no KaTeX in Obsidian.
Ah, thanks
