Version Control / Note history for notes - For linked ideas can we create feature to keep track how the idea is evolving?
We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one. Once you’ve searched and determined that this is a new request, delete this line.
I would like to keep track of my prevous thoughts and how they evolve.
Also I would love to be able to keep an older version so when I change a linked idea, and becaause of a change in one it breaks the flow on others. So that I can seperate the link and go back to the older version.
There could be a button to keep track of changes that were made in a selected block of text, once that is enabled when a change is implemented, there might be another button to commit or remember.
We can limit it to 10 or something like that if it would make an engineering challange to remember all commits
My solution for this right now create a note for one idea and copy paste it down and change the link to the last version
I couldn’t find any similar request. Do let me know if I missed it
If you use Sync then you have version control at the file level. For finer control you could use a Git repository and GitHub - denolehov/obsidian-git: Backup your Obsidian.md vault with git to give you all the power of Git. There’s a beginner’s guide at https://dannyhatcher.com/obsidian-git-for-beginners/.
