Vault launcher for rofi
Hello there!
I would like to present a small project I made to integrate Obsidian with rofi.
This project came to be because I was frustrated with how Obsidian opens the most recent vault first, requiring to open the vault selector, select the vault I actually wanted, and close the vault it opened in the beginning. Even with an option to display the vault selector, it is possible to bypass this step and go directly to the vault.
It will look something like this (exact result depends on your rofi config):
And after making your selection, Obsidian will open your vault.
The flatpak version and all versions storing configuration files in ~/.config/obsidian are supported.
I would greatly appreciate feedback or thoughts.
