Vault cache truncation after `adapter.write()
Hi, this might be an implementation issue but I want to make sure:
When a plugin writes a file whose new content is **larger** than the previous file size, Obsidian’s internal file watcher transiently overwrites the file on disk with stale in-memory cache (truncated to the **previous** file size) before self-correcting in roughly 1–2 seconds.
During the transient window, anything that reads the file from disk (e.g. `node:fs.readFileSync`, an external sync tool, an integration test, or another plugin) sees a truncated copy. `vault.read()` is unaffected because it serves from the in-memory cache, which has the new content the entire time.
The truncation **always self-corrects** without further plugin action — the watcher rereads the disk content and reconciles. But for ~1–2s the on-disk state and the cache state disagree.
## Environment
- **Obsidian version:** 1.12.7
- **OS:** macOS *(also reproduced on Linux via Docker live tests)*
- **Plugin context:** Custom plugin writing markdown notes via `app.vault.adapter.write()` and verifying via `node:fs/promises.readFile()` in an integration test harness running in the same process / vault.
## Reproduction
Minimum reproducible scenario in any plugin:
```typescript
// 1. Create a small file
await app.vault.create(‘test.md’, ‘Hello’); // 5 bytes
// 2. Read it back via vault — fine
const cached1 = await app.vault.read(file); // “Hello”
// readFileSync(‘test.md’) === ‘Hello’ // ✓
// 3. Update with LARGER content
await app.vault.adapter.write(‘test.md’,
‘Dies ist ein deutlich längerer Text’); // 36 bytes
// 4. Read immediately
const cached2 = await app.vault.read(file); // ✓ correct, 36 bytes
const onDisk = readFileSync(‘test.md’, ‘utf-8’); // :cross_mark: "Dies " (5 bytes!)
// 5. Wait ~2 seconds
await sleep(2000);
const onDiskLater = readFileSync(‘test.md’, ‘utf-8’); // ✓ correct, 36 bytes
### Verified size matrix
| Operation | Disk state immediately | Disk state after ~2s |
| Create 5-byte file | `“Hello”` ✓ | unchanged ✓ |
| Update same size (5 → 5 bytes) | correct ✓ | correct ✓ |
| Update smaller (36 → 5 bytes) | correct ✓ | correct ✓ |
| **Update larger (5 → 36 bytes)** | **truncated to 5 bytes** :cross_mark: | **correct, 36 bytes** ✓ |
The trigger is **growing** content with respect to the previous on-disk size. Same-size and shrinking writes are unaffected.
### Why we believe this is a watcher race
- `vault.adapter.write()` writes the correct full bytes via Node’s `fs` module — verified by inserting a `readFileSync` call directly between `write()` and the next event loop tick: the bytes are right.
- A few milliseconds later, the file watcher fires and the on-disk content drops back to the **previous** `file.stat.size` worth of bytes.
- ~1–2s later, the watcher fires again and the file is restored to the new full content.
This pattern is consistent with the watcher running its reconciliation path and using a stale `file.stat.size` for an `ftruncate`-like operation, then re-reading and correcting.
## Impact on plugins
| Use case | Affected? |
| User editing notes in the Obsidian editor | No — editor reads from cache |
| Plugin reading via `vault.read()` | No — cache is correct throughout |
| Plugin reading via `vault.adapter.read()` | **Yes** — adapter reads from disk |
| Plugin reading via `node:fs` directly | **Yes** |
| External sync tools (Syncthing, rsync, Git) | **Yes** — may sync truncated state |
| Integration tests verifying writes via `readFileSync` | **Yes** — flaky without delays |
| MCP servers / remote clients reading via the Vault API | No |
## What we tried before settling on the workaround
| Approach | Outcome |
| `vault.modify(file, content)` | Same truncation symptom — cache flush uses stale `stat.size` |
| `vault.process(file, fn)` | Same truncation symptom under the same growing-content conditions |
| `adapter.write` followed by `vault.read` to “warm” the cache | Triggers an additional flush, causing a *second* truncation race |
| `adapter.write` only, then read `stat` via `adapter.stat` | **Works** — the file watcher self-corrects, and we never re-touch the cache after the write |
## Current workaround in Kado
`src/obsidian/note-adapter.ts:50-61`:
```typescript
async function updateNote(app: App, request: CoreWriteRequest): Promise {
const file = app.vault.getFileByPath(request.path);
if (!file) throw notFoundError(request.path);
// Obsidian bug: vault.modify()/process()/read() after adapter.write() can
// truncate the file back to the previous size. Any vault cache interaction
// triggers an internal flush with stale stat.size. Workaround: write ONLY
// via adapter, get stat from adapter, and let Obsidian discover the change
// through its file watcher (which correctly re-reads the full file).
await app.vault.adapter.write(file.path, request.content as string);
const stat = (await app.vault.adapter.stat(file.path)) ?? file.stat;
return {path: request.path, created: stat.ctime, modified: stat.mtime};
This violates the Obsidian Plugin Guidelines recommendation *“Prefer the Vault API over the Adapter API”*, but is the only approach we found that consistently produces correct on-disk state without requiring an artificial delay.
We are deliberately **not** doing any of the following after `adapter.write()`, because each one re-triggers the truncation race:
- `vault.read(file)`
- `vault.modify(file, …)`
- `vault.process(file, …)`
- `vault.cachedRead(file)`
Reading `app.vault.adapter.stat(path)` is safe — it goes straight to the filesystem and does not touch the cache.
## Expected behaviour (from the plugin author’s perspective)
After `await vault.modify(file, content)` (or equivalently `vault.process` / `adapter.write`) resolves:
1. `vault.read(file)` returns `content` — **already true today**
2. `app.vault.adapter.read(file.path)` returns `content` — **currently false in the truncation window**
3. Any external observer reading the file from disk sees `content` — **currently false in the truncation window**
In other words: when an `await`ed write resolves, the file should be persisted in its final state, with no further reconciliation pending.
## Related code paths in Kado
- `src/obsidian/note-adapter.ts:50` — `updateNote()` uses the adapter-only workaround
- `src/obsidian/inline-field-adapter.ts:243` — `writeFields()` uses `vault.process()` because inline-field updates rarely grow content significantly. If the truncation race is reproducible there too, this will need the same workaround. *(Add a note here once verified.)*
- `src/obsidian/file-adapter.ts:70` — `vault.modifyBinary` for binary files. No `processBinary` API exists; behaviour under the truncation race is **unverified**.
- `test/live/mcp-live.test.ts` — live integration tests verify writes via `node:fs.readFileSync`. The current `updateNote` workaround makes these stable; changing the strategy would re-introduce flakiness.
## Suggested upstream fix (priorities, low to high)
1. **Documentation**: clearly state in the Vault API docs that on-disk state may transiently lag the cache state by 1–2s after a write that grows the file. Plugin authors who only read via `vault.read()` are unaffected and don’t need to care; everyone else needs to know.
2. **API**: provide a way to await full disk reconciliation, e.g. `await app.vault.flush(file)` or have `vault.modify()` not resolve until the watcher reconciliation has completed.
3. **Bug fix**: have the cache flush use the *current* in-memory content’s byte length for `ftruncate`, not the stale `file.stat.size`. This appears to be the root cause: the watcher reconciliation truncates to the previous size before re-reading the new bytes.
Hmm… does somebody know how to get the tables to work easily?
Thanks for the report. We will review this.
Your analysis makes no sense.
Vault.read just calls Adapter.read, there is no cache. The only time cache is involved is Vault.cachedRead. Adapter.readis a direct fs.promises.readFile so it would be otherwise identical to reading the file using nodejs directly.
The file watcher system is just a watcher, not a writer. Its only job is to fire a series of events when files are modified; it does not read or write file contents.
I am also unable to reproduce from your instructions:
I suspect you have a plugin installed that is doing something strange, perhaps intercepting vault or adapter calls, or perhaps doing something with editor files. The 2 seconds is suspicious because that’s how long it editor changes are debounced before they are saved to disk.
I agree. I suspect the test code doesn’t match the real code causing the issue. Maybe in the real code the author deals with CodeMirror editor and makes the change to it. Then in 2 seconds it’s automatically saved and file is updated.
let me figure that out. the test vault for the plugin (which is in this thread) only has hot reload and the plugin installed.
So it might have something to do on how the tests are written.. using mcp to read / write together with file access checking.. OR I have a bug in my plugin.
OR… I had the note open?
I can’t reproduce it so thanks to all!
BTW: does somebody know how to copy / paste tables into this forum? the text I posted at the beginning looks disgusting.. but I totally forgot to clean it up… sorry for putting you through this.
