When you create a remote vault for Obsidian sync, the password is hidden. If you made a typo, you may not be able to enter the password correctly to encrypt/decrypt the remote vault.
There are two possible solutions:
Allow the password to be visible when typing (this could be an option that could be toggled)
Validate the password by asking the user to re-type it
None that I am aware of. Just kept my fingers crossed
My keyboard has issues with the shift key, so I’m not always sure that I successfully type a capital letter.
