V1.8.3 Re-org of right click? Where has "Open in Default App" gone?
Has anyone seen where “Open in Default App” and “Reveal in System Explorer” have gone?
Expected behavior:
  • Right click on the embed code (eg ![[radical_image.gif]] of an embedded image such as a jpeg or png
  • From the pop-up, select either the “Open in Default App” or “Reveal in System Explorer” option
Tried:
  • Looked in the changelog for documentation of this change
  • Ditto for official user guide
Thanks! :slight_smile:
Hmm :thinking: … I can’t repro with Obsidian 1.8.3 :thinking: (on a MBP + MacOS Sequoia 15.2)
I’ve tested with the Native menus (under Obsidian’s Settings > Appearance > Advanced) enabled and disabled but what ever wikilink I right-click on, both options still appear…
Did you try to locate Open in Default App and Reveal in System Explorer in the Sandbox Vault ? (Restricted Mode toggled On + Default theme, etc…) :blush:
Ah, yes, you’re right…when I turned on Restricted Mode, it was fixed. Strangely, when I turned Restricted Mode back off, it was still fixed :thinking:.
Anyways, considering this one resolved. Thanks for the reminder! :pray:
