Using regex in Bases
Hi, I’m trying to get with the new Bases plugin.
I’d like to filter files that two capital letters as filename. I.e. VD.md, SO.md and so on.
I’d like to know if I can somehow use regex for this.
I’ve tried this file.name.contains("^[A-Z]{2}\\.md$") but no success.
You could try using matches() instead :blush: :
/^[A-Z]{2}$/.matches(file.name)
or, if you want to use the fullname (the name + extension) of the note, like you did, this seems to work:
/^[A-Z]{2}\.md$/.matches(file.fullname)
Perfect, thank you! I did try matches but I must’ve used it incorrectly.
