Using Obsidian in the Cryptomator virtual drive, the index is rebuilt every time it is opened
I use cryptomator to encrypt my note repository, and then use the winFsp drive virtualized by cryptomator as the obsidian repository location. But each time the obsidian vault is reopened, the index becomes invalid and the entire repository needs to be re-scanned. May I ask if there are any solutions?
When opening obsidian notes in the cryptomator virtual drive, do not rebuild the index anymore. Instead, you can use the cache
There was no problem when trying to use the notes in a regular drive. It’s confirmed that the issue is due to the Cryptomator virtual drive.
Try using winFsp (Local Drive)
