I am not sure how to word this request. I am trying to add symbols the degree symbol, TM for trademark, Circle-C for copywrite, TM for trademarketc. I tried searching the Obsidian forum for help on this. Any help would be appreciated.
On mac you can use built in Character Viewer or Raycast’s Emoji & Symbols.
On windows there is similar feature:
The task of inputting typographic symbols, such as the degree (°), trademark (™), and copyright (©), is not the responsibility of the Obsidian application, but rather a fundamental function of the underlying operating system. Consequently, the methods for typing these characters vary significantly across different operating systems.
1. Windows Operating System
- Alt Codes via Numeric Keypad: This method requires a physical numeric keypad and involves holding the
Altkey while typing a 4-digit decimal code.- Degree (°): The code
Alt + 0176requires 4 keystrokes plus 1 modifier . - Trademark (™): The code
Alt + 0153requires 4 keystrokes plus 1 modifier . - Copyright (©): The code
Alt + 0169requires 4 keystrokes plus 1 modifier .
- Emoji and Symbols Panel: Pressing the
Winkey and the period key simultaneously (2 keystrokes) opens a graphical interface for inserting symbols . - Microsoft Word AutoFormat: Within Microsoft Word, typing
(c)automatically converts the 3-character string into the 1-character copyright symbol .
2. macOS Operating System
- Option Key Shortcuts: macOS provides highly efficient shortcuts utilizing the
Option(Alt) modifier, reducing the input time to just 2 or 3 keystrokes per symbol.- Trademark (™): The shortcut
Option + 2requires exactly 2 keystrokes . - Copyright (©): The shortcut
Option + Grequires exactly 2 keystrokes . - Degree (°): The shortcut
Option + Shift + 8requires exactly 3 keystrokes .
- Character Viewer: Pressing
Control + Command + Spacebar(3 keystrokes) opens the Character Viewer, allowing users to search for and insert symbols .
3. Linux Operating System
- Compose Key Sequences: Linux utilizes a configurable “Compose” key followed by a 2-keystroke sequence, resulting in a highly efficient 3-keystroke input method.
- Degree (°): The sequence
Compose + o + ogenerates the degree symbol . - Copyright (©): The sequence
Compose + o + cgenerates the copyright symbol . - Trademark (™): The sequence
Compose + t + mgenerates the trademark symbol .
- Unicode Hex Input: Pressing
Ctrl + Shift + U, releasing the keys, typing the 4-digit hex code, and pressingEnterrequires 7 keystrokes but works universally across all Linux environments. - Third layer keys: Pressing
3_layer_key + dfor °,+ tfor ™ and+ cfor ©.
4. Mobile Operating Systems (iOS and Android)
- Long-Press Interaction: Mobile keyboards utilize a long-press (sustained touch of approximately 0.5 seconds) on specific keys to reveal a pop-up menu of typographic variants.
- Degree (°): Long-pressing the
0(zero) key on the virtual numeric keyboard yields the degree symbol. - Copyright (©) and Trademark (™): Long-pressing the
CorTkeys on iOS, or navigating to the secondary symbols menu on Android, provides these characters.
@LemeRus Did you verify that these all actually work? (The Linux ones especially seem like they might vary depending on which Linux)?
On Mac, it might also depend on the keyboard …
I mean, on my MacBook Pro:
- Degree (
°) is Shift + ) - Trademark (
™) is Option + Shift + t - Copyright (
©) is Option + c
For linux and windows yes. For android only for my phone (mi 12 lite), not all virtual keyboards work same. Mac — no, but for some locales this seems true.
OK. Please don’t post unverified AI output. Thanks!
thank you
I do not care whether or not it is the responsibility of Obsidian. This is not a legal forum, rather a forum where users can help others.
Now, with that said, thank you for the help in understanding how I would go about inserting these symbols. I tried to search the web and got nothing on what i was looking for. A simple request that AI driven algorithms over complicate life at times. Back in my Unix, MAC and DOS days, I had cheat charts for each of my separate systems. My word processing applications had these symbols built-in. My digital typesetter integrated symbols into my technical documents.
I am using Obsidian on a MacAir, a Windows PC and three phones: two android, and one iPhone. “Sometimes”, I get a senior moment or two…
Your robust reply is most appreciated.
I will put it on an “index card” for reference.
testing: ™, ©, °. (using a MacAir - wow, how satisfyingly easy.
Thanks again
Thank blue_emperor,
I don’t use Emogi’s much aside a simple smile or two. I am working with technical (scientific and engineering) documents. I’ll be sure to hand on to your answer. I am sure it will come in handy in the future.
On raycast if you search “symbols”, you will see this
I have also set global keyboard shortcut for Emoji & Symbols which is ⌃⌘Space. I use ⌘Space to open Raycast.
In Emoji & Symbols you can search by keyword:
In the default view you get frequently used symbols:
If your symbol is not found then you can use unicodeplus.com etc to find your symbol and then store it in raycast snippets. For example I use U+00A0 (no break space), U+2011 (non breaking hypen), U+205F (medium mathematical space), U+2009 (thin space), U+200A (hair space). Thin and hair space is not always rendered properly across different software. If you use LaTeX/MathJax, then proper spacing happens automatically or with LaTeX specific syntax.
