I want to be able to insert a value from my inline metadata (example: “status:: done”) into a Templater script.
This works (as Templater documents) when I insert the metadata into the front matter and use <% tp.frontmatter.status %>. This does’t for for inline metadata.
Just wondering if there is a way to access inline variables are part of a Templater script?
thanks!
Hi. My knowledge of Templater is almost zero. So, I can’t help your directly. But you can use a dataview inline query:
`=this.status`
