  • Create two obsidian vaults “VaultA” and “VaultB”
  • On desktop, create two shortcuts (right-click, new, new shortcut) using the following URL-scheme for each, accordingly.
    obsidian://vault/VaultA
    obsidian://vault/VaultB
  • Launch one of the shortcuts.
  • If the problem doesn’t appear, close that vault and open the other shortcut.
Each vault opens individually
One of the shortcuts will work correctly. The other one will launch both vaults at the same time.
  • Obsidian version: Obsidian v0.10.1
The bug might switch to the other shortcut (the one previously working correctly) when you close all vaults and repeat the process a number of times.
will be fixed 0.10.5
Thank You!!!
