Using dataview to highlight lines
I’m trying to highlight parts of a markdown document, and also show highlights from entire document at the top.
I setup a hotkey via quick-add macro to move selected content inside [highlight :: ], which I can then query with dataview LIST. This is working okay, however, the LIST query returns highlighted lines in random order, with order changing every dataview refresh. Is there a way to LIST attributes in order they appear in document ?
Basically, I have a document containing [highlight:: first highlight], …some text…
[highlight:: second highlight], …some more text… [highlight:: third highlight]. With a LIST highlight query, I am getting all the highlights, but not in order. Is there a way to make sure they appear in order ?
Having a note with:
You can try
```dataview
LIST h
WHERE file.name = this.file.name
flatten highlight as h
sort h DESC```
Output:
* note: third highlight
* note: second highlight
* note: first highlight
What kind of query did you do? If I do this query:
```dataview
LIST aHighlight
WHERE file = this.file
FLATTEN highlight as aHighlight
It do come out in order for me. Even without the FLATTEN it comes out in the order they’re defined in the file.
If you add the SORT h (or SORT aHighlight) it’ll sort them according to alphanumerical value of the highlight, which might not be the order you’ll want them to have.
Does the result order remain stable in your setup on adding/editing highlights ?
My query is a simple LIST from this.file without FLATTEN or SORT. Results are initially in order defined in file, but on editing/adding more highlights this order is being scrambled. Not sure if it’s due to any other plugin on my setup.
