I’m using the Pandoc plugin and depending on where I am in my vault, sometimes I want to convert with specific options; other times, I want to use the defaults.
The way the Pandoc plugin works, I have to specify any command-line option (–defaults) in the global setting. If the file isn’t present in a folder, the whole thing fails.
I would like the ability to set a default local config file and have Pandoc load it if it’s there and apply whatever the rules of --defaults are. Otherwise, it uses the global defaults.
I tried creating a Powershell script and using that as the path but when I execute it, nothing happens.
Maybe I’m not doing it right (I’m not a PowerShell/Windows expert; I’m more comfortable with Linux CLI but…) or maybe this use case is unsupported.
Maybe you need to mark the script file as executable? I’m not familiar with how this stuff works on Windows, but on Mac and Linux that’s a thing that needs to be done.
On Windows the extension of the file determines what you can do with it. When you “execute” a file from the command line, it runs it with the default program associated with the extension. I tried with PowerShell and CMD (the equivalen of bash, I guess) but neither of them work. It looks like the extension requires the executable binary (an exe file).
While researching this, I saw that there is an extension to execute arbitrary commands from within Obsidian. I might end up using that and creating my own version of the Pandoc plugin. Or, at least, a reasonable facsimile.
However, if someone has found a way to do this with the original plugin, I’m still open to it.
