Specifying a URI to open a document, e.g. a PDF, of the form [alias](file:///path/to/file.pdf)
works as expected (tested on Windows) and opens the specified file.
With URIs, it should also be possible to specify page numbers in PDFs, e.g. [alias](file:///path/to/file.pdf#page=10)
Executing this code in the terminal with e.g. Microsoft Edge does indeed open the file at the specified page. I would expect this to work in Obsidian too.
However, an URI of this form in Obsidian throws the following error:
Windows cannot find
‘path/to/file.pdf#page=10’.
Make sure you typed the name correctly, and then try again.
Which makes me believe that Obsidian is somehow passing/decoding the URI incorrectly, since the exact same URI works in the terminal.
- Operating system: Windows 11
- Debug info:
Obsidian version: v1.1.16
Installer version: v0.14.6
Operating system: Windows 10 Pro 10.0.22621
Legacy editor: off
Base theme: light
Snippets enabled: 3
Plugins installed: 12
Plugins enabled: 7
1: Excalidraw v1.8.14
2: Citations v0.4.5
3: Dataview v0.5.47
4: Copy Image and URL context menu v1.4.0
5: Text Snippets v0.1.2
6: Pandoc Plugin v0.4.1
7: Quick Latex for Obsidian v2.5.1
