University Workflow v2 for Obsidian - Smart templates for academic notes
Obsidian University Workflow v2 :graduation_cap:
Smart templates for organized academic notes
Stop managing folders, start capturing knowledge
:sparkles: What This Does
Tired of university notes sprawling across random folders? This workflow gives you:
  • :brain: Smart Templates that auto-file your lectures, concepts, and notes
  • :gear: One Config to customize all labels and folders for your language/vault
  • :bar_chart: Auto-Dashboards that populate as you take notes
  • :shield: Guardrails to prevent misplaced files and duplicates
:rocket: Quick Start
  1. Install Templater plugin in Obsidian
  2. Copy the _templates and _templater_scripts folders to your vault
  3. Configure Templater to use those folders
  4. Run β€œLecture Note” from a new untitled note
That’s it! The templates will guide you through subject selection and handle all the organization.
:bullseye: Templates Included
Template Purpose Best For
Lecture Note :microphone: Daily class notes Capturing lectures with structured sections
Concept Note :light_bulb: Deep topic understanding Feynman-style concept breakdowns
General Note :memo: Flexible academic notes Research, references, ideas
Subject Hub :house: Course dashboard Overview of all course materials
Assign Tema :counterclockwise_arrows_button: Retrofit organization Adding structure to existing notes
:wrench: Key Features
  • Config-First Design - Change folder names/labels once in universityConfig.js
  • Auto-Detection - Templates detect your courses and exam periods
  • Mobile-Friendly - Works on Obsidian Mobile once templates are synced
  • Dataview-Ready - Built-in dashboards and backlinks
  • Safe File Handling - Prevents overwrites and naming collisions
:books: Learn More
This is just the overview! The full documentation includes:
  • Detailed configuration guide
  • Template customization options
  • Troubleshooting common issues
  • How to extend the system with new templates
  • Complete technical conventions and frontmatter schema
:backhand_index_pointing_right: Explore the full documentation on GitHub β†’ obsidian-university-workflow - By ABO896
Open source β€’ MIT License β€’ Built for students by a student
5 posts were merged into an existing topic: Obsidian University Workflow β€” Templater-powered notes for students
