Unable to create or move vault on OSX Sequoia
I am trying to set up Obsidian Sync, so I need to either move my vault, or point Obsidian at a new folder, and move the vault there manually. Choosing either option causes the Spinning Beachball of Doom cursor, then nothing. It stops and nothing happens. I try again for either option, same result. I can use my vault, but can’t manage it.
I haven’t found anyone else with this problem. Sequoia has had some quirky problems, so I made certain that wasn’t the case before coming here. I reinstalled Rosetta to make certain it wasn’t an Intel/silicon communication issue, I hunted for all possible computer problems, and I am now working off of a clean install of the operating system, and a clean install of Obsidian. Still the same result–the wait-a-minute cursor with no action afterwards. Any suggestions?
